Alan Field Posted February 10, 2021 Posted February 10, 2021 I'm installing a Zetec Silvertop into my SEiW. It previously had a CVH. I'm seeking a few parts, noteably: 1. Engine mount for inlet side. 2. Sump. 3. Splash-plate for bell-housing. 4. Weber 45DCOEs with 5 progression holes. 5. Ignition only ECU. There may be other parts that I will need, so I'd be interested in anything you may have removed when upgrading from a Silvertop to a more modern engine. Thanks a lot.
Nick Lester Posted February 10, 2021 Posted February 10, 2021 Hi Alan, I will shortly be able to sort you out with an engine mount for the inlet side. I can look into postage or you are welcome to collect if you prefer (am in Watford) Thanks Nick
1960dave Posted February 10, 2021 Posted February 10, 2021 I have a inlet plenum and a westfield loom for the standard ford ecu with ecu if you have trouble finding some carbs.
1960dave Posted February 11, 2021 Posted February 11, 2021 I have a pair of Dellorto dhla's jetted for a 2.0 silvertop with manifold. Plus a Westfield supplied ecu mapped for a 2.0 silvertop as well with all sensors for sale
