SOLD - Stack 88mm Electronic Programmable Speedometer - Black Dial
Only been trial fitted, hence odometer still reads zero.
£175, buyer pays delivery costs.  Sensible offers considered.
If you require a speed sensor I have a Stack ST670 speed sensor that I can include for an additional £100, normal retail on the sensor is £165.
Reason for sale is that I've been offered a Stack 8130 dash so this speedo and the ST700 tachometer I listed previously wouldn't be required.
  • Fully user programmable.
  • LCD odometer with a re-settable trip displays.
  • Compatible with most OE vehicle speed sensors, as well as aftermarket speed pulse generators
  • Maintenance free through the dial white LED backlighting.
  • LED illuminated needle for maximum visibility.
  • 80mm visible dial dimension, requires 85mm cutout.
To avoid any confusion this is not the GPS version.
  • Master O changed the title to SOLD - Stack 88mm Electronic Programmable Speedometer - Black Dial
