SOLD Full Roll Cage and Fittings Narrow Live axle
Selling as have now sold my chassis, want £650 collection is from Somersham Cambridgeshire
Hi there can you supply me with the center to center dimensions of the outermost bolt holes of the roll over hoop mounting points
regards Craig
regards Craig
Hi Craig, Do you mean the mounting points directly behind the back of the seats. If so the the outer bolt is roughly 91cm apart center to center give or take a few mm as trying to measure on my own with a touch
torch
Yes that’s what I was looking for
thanks Craig
Hi Adam, is the cage still available?
Could I have the width across the front at the bottom (ie width at the scuttle).
Collection shouldn’t be a problem.
Hi Charles, Measures 94cm wide at the last bolt. This is situated 10cm from the edge of the scuttle which joins the bonnet. Please see photo. If yours is a Narrow SE this will fit.
Pre Litigation SE, so most things fit, but not everything! Scuttle measurements matches here and there aren’t any mounts other than roll bar on the chassis so I can move the odd mm when I weld them in!
 I’ll drop you a PM to sort out payment, etc.
  • AdamHolmes changed the title to SOLD Full Roll Cage and Fittings Narrow Live axle
