***SOLD*** Ford Type E 4 speed gearbox with Quaife straight cut close ratio gears
As above.
Ideal for sprint or hill climbing car.
Sounds great.
All working as it should.
Cleaned and painted.
Viewing welcome.
Collection only from Chester area.
£750 ovno.
  • Nick Clarke changed the title to Ford Type E 4 speed gearbox with Quaife straight cut close ratio gears
bl**** brilliant gearboxes these, especially for track use. 15kg saving over a T9!
It sounds exactly what I need, but I don’t have £950 :(
  • Sad 1
Do you know the ratios? it might help interest more people.
No I don't, it was on the car when I purchased it.
These are the current ratios for Quaife's Rally/Race gear kit:
2.480/1.690/1.210/1:1
The gear kit alone is around £1200.
Hope this helps.
Reduced to £800 ovno.
  • 3 weeks later...
  • 2 weeks later...
Reduced to £750.
I also assume this is a syncro box and not dog engagement? Also is it a short or long input shaft?
Yes it is a syncro box and has the short input shaft.
  • Nick Clarke changed the title to ***SOLD*** Ford Type E 4 speed gearbox with Quaife straight cut close ratio gears
