Carl Warren Posted November 2, 2020 Posted November 2, 2020 Wanted, tub kick strips.. must be a standard westfield item, westfield haven’t any in stock and don’t know when any are coming. I need this to pass the Iva, ideally new will consider used in good condition though.
Ian Kinder (Bagpuss) - Joint Peak District AO Posted November 2, 2020 Posted November 2, 2020 They don't look too difficult to make. A piece of aluminium with some foam stuck on then covered in vinyl. Says the man who fitted factory supplied items!
Steve (sdh2903) Posted November 2, 2020 Posted November 2, 2020 Why do you need them for IVA? I've not fitted any on the 2 I've built Or are these the bits that cover the scuttle bolts?
Carl Warren Posted November 2, 2020 Author Posted November 2, 2020 12 minutes ago, Steve (sdh2903) said: I was under the impression I need them ? And carpet for tunnel .. or atleast something for the tunnel edge ?
Carl Warren Posted November 2, 2020 Author Posted November 2, 2020 33 minutes ago, Ian Kinder (Bagpuss) - Joint Peak District AO said: They don't look too difficult to make. A piece of aluminium with some foam stuck on then covered in vinyl. Says the man who fitted factory supplied items! Last resort matey. If I can buy them made I will 👍
Carl Warren Posted November 2, 2020 Author Posted November 2, 2020 16 minutes ago, Steve (sdh2903) said: Or are these the bits that cover the scuttle bolts? The bit that your elbow touches when sitting in the car.
Steve (sdh2903) Posted November 2, 2020 Posted November 2, 2020 Tunnel edge yes but if your not wanting carpet long term id just fit some rubber trim
Gary Taylor Posted November 3, 2020 Posted November 3, 2020 Re tunnel edges I just used rubber U trim on the carbon top panel edges to give a “ blunted” edge instead of the sharp square edge. Bodywork section was left as is
