**2004 Westfield SEiW 20XE** NOW SOLD
HISTORY
This Westfield was built from a brand new standard wide-bodied kit by Leon Boutell. I bought it in 2007 with 9,000 miles on the clock. It's now done about 30k all told, most of it in Yorkshire (where I became Yorkshire AO). We have now retired to Norfolk but the car has also been down to Cornwall and up to Northumberland for holidays too. So, it’s great for trips out and for touring but we’ve also been to trackdays at Croft, Cadwell, Blyton, RAF Marham and Snetterton where it’s performed brilliantly. It’s been modified and improved to my requirements and currently weighs just over 600kg. I’m selling it as I now have a Rocketeer MX-5 with a 3.0L V6!
ENGINE
An early Vauxhall 20XE Redtop
AE 86.5mm pistons
Balanced bottom end
Standard cams
Jenvey 45mm throttle bodies with 90mm ram pipes
New RamAir air filter
DTA E48 management system and custom loom
QED cast alloy shallow sump
Accusump (fitted but not yet plumbed in)
Blue silicone cooling hoses
AH Fabrications alloy oil catch tank and water swirl pot
SBD 4-2-1 exhaust manifold and downpipe
Simpsons 7x29" can recently repacked with Acoustifil
New Coolex alloy radiator, fan and low temp fan switch
Fuel swirl pot and red top lifter pump
Lightweight alternator
Mapped by Northampton Motorsport to produce 185 bhp and 168 ft lbs of torque
TRANSMSSION
SBD lightened standard pattern 16V XE flywheel
228mm 2.0 16V VX Helix sprung paddle clutch
SBD 150mm vertical Ford/Vauxhall alloy bellhousing
Ford Type 9 recently fully rebuilt by ‘Windy’ with a long first gear
3.92 LSD
STEERING
Rally Design quick rack
Alloy rack mounts
BRAKES
Hi Spec Ultralite 4 front brake callipers
Mintex M1144 brake pads (front)
New discs and standard brake pads (rear)
Wilwood brake bias valve
Uprated AP master cylinder
Electric brake light warning switch
WHEELS AND TYRES
15” gloss black Team Dynamics Pro Race 1.2 wheels
Recently fitted Toyo R1R tyres
SUSPENSION
GTS Widetrack front wishbones
Cat Motorsport lightweight alloy hubs
Playskool front ARB
Protech shock absorbers
Nylon bushes all round
Suspension geometry and corner weights all set up by ‘AdamR’
INTERIOR
‘Mickmade’ matt finish carbon fibre dashboard
VDO digital speedo, water temp and fuel level gauges
Elliott 0-8k rev counter
SPA combined digital oil pressure and temperature gauge
Racetech quick release steering wheel boss
Westfield Alpha 300mm suede rimmed wheel
A pair of JK Composites black fibreglass seats
5 point black Playskool Racelidz driver’s seat belt
4 point black Sabelt passenger’s seat belt
BODYWORK
Standard yellow tub with detachable rear arches and plain black plastic stone guards
New black nose cone with professionally painted yellow stripe and nose band (to replace existing)
New Carbon NV front cycle wings (to replace existing)
New black bonnet with professionally painted yellow stripe (to replace existing)
Aerodynamix carbon scuttle panel
New yellow scuttle (to replace existing)
FIA Cut off switch
Standard black windscreen and acrylic wind deflectors
Carbon fibre foam laminated rear deck lid
Black gloss powder coated RAC roll bar
New black fibreglass diffuser (to replace existing)
Soft Bits for Sevens half hood with quadrant zip
Aerodynamix yellow grp half doors
Aerodynamix carbon double bubble aeroscreen option
LIGHTS
Standard front headlights with new LEDs to replace existing
Caterham carbon fibre sidelight housings
Remaining lights both inside and out all LEDs
SPARES ETC
There are plenty of spares including engine parts
, the original standard gearbox, a good replacement LSD, etc, which you can have if you want. I also have plenty of books and loose-leaf folders full of all the usual stuff, receipts, etc.
** SOLD **
This Westfield, with a fresh MOT at the beginning of August and next to no miles since, is offered at £8,000 or thereabouts.
I also have a Brian James Minno Max trailer which has been fully serviced and has 4 newish tyres. It will be offered in the first instance to the buyer of the car for an additional £1,000.
If you have any questions, please contact me via PM on this site, by text or phone on 07887 491212 or by email mavanzeller@sky.com. I’m happy to show you the car and to take you out for a short blast round the local roads all in accordance with Covid-19 instructions.
The photos that follow are in date order.
MARTIN ! have you gone mad? :(
You cant do it, move back to Yorkshire and you'll get all your enthusiasm back :d
Good luck with the sale, if you have to :t-up:
  • Rory's Dad changed the title to **2004 Westfield SEiW 20XE** Now just £8,000
Now reduced in price!!
A tough time to sell a car that is ostensibly a toy, but this is just so much car for that money. If I didn't have one I'd snap this up.
Just browse the spec, it is an assembly of parts you probably couldn't buy for 12k and some.
If you don't desperately need the space or the money it is better in your garage until some post Covid spring,
Jim
That is cracking value! Having set the car up I can confirm it's a good un. Yes it has been used plenty, but that just proves good reliability!
Best of luck with the sale, Martin.
  • Rory's Dad changed the title to **2004 Westfield SEiW 20XE** NOW SOLD
