**** SOLD*****.Westfield Seiw 2004 Zetec jenvey throttle bodies omex 600.
Westfield SEIW Aerorace 2004
2.0ltr Zetec Silver top Raceline sump jenvey throttle bodies omex 600ecu....
Specification :
Chassis 2004 SEIW fully overhualed and re coated in 2013 POR15
Fully caged roll cage.... Fia Approved.
Escort 2.4 quick rack steering.
Playskool front and rear anti roll bars.
Front and rear wishbones powder coated.
Powder coated cycle wings brackets and headlight brackets 4" Dominator headlights ultra bright bulbs throughout. 560kg.
Suspension:
Protech front and rear adjustable shocks fitted and set up in 2014 by blink motorsport....
Full system checked over and fully setup again in 2019 re corner weighted, new geo set up, fully laser aligned by Automek... Full report can be supplied by Andrew Baird. All original bushes replaced with nylon bushes.
Engine:
Ford 2.0ltr zetec silver top Mapped by Northampton Motorsport and then more recently by RA Motorsport Russ Paton. 180bhp, reported to be good and strong unit.
Jenvey throttle bodies.
Omex 600 eco with USB cable for access supplied.
Omex file at RA Motorsport.
New pipercross air filter.
New pc680 gel battery fitted in front passenger footwell.
Fia cut off switch.
Spare Clubman sport PVR22 Gel Battery as new.
Alloy catch tank ARP.
New Spark plugs 2019
New Magnecor leads zetec high performance race leads 2020.
New Powerlite starter motor 2019
New Ford Alternator 2019.
Fuel System:
Westfield alloy fuel tank new 2018.
Alloy swirl pot/tank.
All new rubber fuel lines and new tank 2018.
Lift pump to swirl pot and sytec fuel pump to throttle bodies.
Exhaust:
Westfield 4-1 manifold hear wrapped.
Wunoff alloy exhaust new 2019.
Gearbox:
Ford type 9 with quick shift gear stick for rifle slick changes.... Gearbox has been mounted further back so to avoid the use of a extension plate for gear lever.. No issues at all with the gearbox... Very strong and selects every gear as it should do.... 5 speed h pattern.
Quaife gearknob.
Final Drive:
3.92 Sierra lsd
Cooling:
Coolex 55mm core uprated radiator and fan controlled by ecu. 82° star.... 90° fan switch on... Cooling is stable and runs around 82-92 all day....
Ducted Radiator in nosecone.
Blue silicone hoses (Ash performance).
System flushed and filled 2020.
Dunnell cooling.
Brakes:
Front Brakes M16 callipers Burton Power performance grooved discs new 2019.
Mintex 1144 pads.  New 2019.
Rear Brakes Escort mk4 discs M16 callipers.
I use Millers race fluid flushed and changed 2020.
Bodywork:
2018 SEIW wide body bodywork in Westfield black machine polished and in great condition....spare tub supplied also.
V8 High Mould modified bonnet.
Removable scuttle with 4 bolts only.
NV Carbon front splitter.
NV Carbon removable rear diffuser.
NV Carbon door cards removable.
LED rear lights carbon facia.
Carbon nose cannards.
Fia rain light installed.
Carbon Fibre:
Aerodynamix full carbon aeroscreen.
Aerodynamix full dash.
Aerodynamix front cycle wings wrapped around tyres.
Aerodynamix Carbon rear panel.
Carbon Mods sill protectors.
Carbon Mods stone chip guards.
Interior:
Jk composites carbon tipped race seats very comfortable.
Black padding / white piping.
Playskool/Racelidz 4 point harness seat belts.
Rapid racing quick release boss.
Momo 260mm suede steering wheel new 2020.
Race technology dash 2 Pro with ecu interface oil pressure, coolant temp and wheel speed sensors all calibrated and works exactly how it should do. Blue led back light for driving in the dark.
Savage switches.
Auto cancel indicators.
Repositioned fuses and ecu to drop down plate on passenger side very tidy layout, easy access all labelled. Omex 600 ecu is stored in there with USB easy access cable to plug in.
Wheels and tyres:
New Avon Zzs rubber 2020.
215/55/13 rears.
185/55/13 fronts.
New Satin black 3 piece split rims by force racing custom built, Superlight and strong.
Rears are 8x13 pcd 108 4 stud fitment.
Fronts 7x13 pcd 108 4 stud fitment.
The car comes with an extensive history and build folders from original purchase receipts and a fully colour folder of its complete rebuild back in 2013...car has been fully serviced by local garage and myself... Runs and Mapped on 99ron fuel. Binders and folders all supplied... The car is road legal and all mots history v5 log book supplied. Two fia keys, two fuel cap keys. The car has been an absolute blast to own and develop. Its a very reluctant sale.... New circumstances has changed which is why I have decided to sell the car but I am in no rush. For all your questions and answers contact Daryll on 07841597991
Mot'd 18/06/2021  if you want more pics then just pm me or email darylldaz@aol.com
£15995 ono.
  • Like 4
******SOLD******
