thos Posted January 22, 2004 Posted January 22, 2004 Hi all, Apologies for this newbie question, but which side will my starter motor be on ? I've got a MT75 gearbox ? I'm ordering myself a nice new Raceline sump, and if the starter is on the left, then they need to do a little modifcation ? Any help would be greatly appreciated !! Quote
deano.1 Posted January 22, 2004 Posted January 22, 2004 Not 100% on this but i believe it depends on wether you have a cable clutch or a hydraulic clutch but just at the moment i cant remember which way round it is, ill try to find out for you. Quote
steppenwolf Posted January 22, 2004 Posted January 22, 2004 I have the following:- 1. Raceline Sump ( which they modified to suit the starter) 2. Hydraulic clutch 3. The starter on the offside HTH Quote
simoke Posted January 22, 2004 Posted January 22, 2004 We've got: 1. Raceline Sump, couldn't modify to suit original starter, had to buy a new one in the correct orientation. 2. Cable clutch 3. The starter on the nearside If that helps!! Quote
Ian Podmore Posted January 23, 2004 Posted January 23, 2004 MT75 Standard sump..... Cable clutch Starter on nearside Quote
thos Posted January 23, 2004 Author Posted January 23, 2004 Cheers guys, I was in work at the time, and couldnt double check the car. For the record, (after checking) it's hydraulic, and on the nearside, so the sump shouldnt need modifiying. Thanks again. Tom Quote
