SOLD- Westfield SEIW 2005 ST170 + trailer
2005 SEIW originally built and Iva'd by Dave Eastwood . Completely rebuilt by Julian Eisel with all parts new or reconditioned apart from engine between 2015 to 2018. I purchased the car in 2018 and completed a cooling system upgrade, cylinder head upgrade, engine calibration development with OMEX to run VVT and fitted new seats.
Engine
Ford ST170
Cylinder head skim and fully rebuilt with new valves, kent cam bucket shims
Exhaust Cam reground to increase lift
Westfield exhaust manifold
Carbon exhaust silencer
ST170 intake manifold and injectors
GSXR throttle bodies
Tiger ERA baffled sump
Dan ST intake trumpets 90mm long
Pipercross C604D Air filter
OMEX 710 ecu (Sewell serial adapter cable for OMEX map 4000)
Custom made engine wiring harness including lambda sensor plug
Hi torq starter motor
Mocal oil take off plate with remote oil filter
ST170 oil to coolant heat exchanger
Raceline water rail
Coolex 55mm Aluminium radiator
82⁰C Thermostat
New Bosch Ht leads
ECU calibrated by OMEX and EFI-parts to produce 204.9 bhp / 180.7 ft/lbs with VVT working (the first known application of the OMEX 710 on a standard ST170 with VVT working)
Driveline
GEARBOX !!! Quaife QBE56G rated for 375bhp recently stripped checked and rebuilt (no longer sold by Quaife but they were over £3,295.00 new )
New clutch
lightweight flywheel
New aluminium bellhousing
Rear diff - LSD 3.62 recently rebuilt
Chassis (full rebuild 2018)
Chassis stripped and all holes welded
Chassis and wishbones powdercoated in graphite grey
New protec shocks and springs
Team dynamics Pro Race 1.2  7x13” ET23 alloy wheels
Toyo 888R tyres 185/60/13 front 205/60/13 rear
Front calipers  4 pot Westfield hi specs with solid crossdrilled discs .
Rear calipers rebuilt Sierra
Body (full rebuild 2018)
New JK composite seats
6-point TRS harnesses
Carbon fibre interior panels apart from floor (powdercoated aluminium)
Carbon fibre dashboard, gearknob, handbrake grip, steering column sleeve, pedal box cover, FW bootlid cover, rear diffuser
Red FW side and back
Black ZK nose and V8 bonnet
LED rear ligths
MSA rollbar
Spares
used scuttle, windscreen, doors and wipers
Carbon wheel arch protectors, mirror covers, cage mount covers
Recent engine oil (5w30), gearbox oil (75W90) and coolant change, Large pile of receipts
Asking for £11,995 ono
Location Nantwich Cheshire
Also available
 Ifor Williams CT115 single axle trailer - £1500
Set of 13”x6” Ford alloy wheels with new 175/70/13 rain expert tyres - £350
Hi, I've pm'd you.
Cheers,
Kirk
  • 2 weeks later...
