Looking for some xe hydraulic cams fast road, kent ast1603, Newman ph4, SBD etc.
Cheers Tony
Bump
  • 2 weeks later...
Bump😁
What are you up to Tony, downgrading, though yours was a 208 kit?
Jim
  • Haha 1
Jim
Hi Jim just looking for more bang  just going to pop these little rascals in20200807_174529.thumb.jpg.15082ce1e23693ea0b4343f80de51990.jpg
Steel rods bigger injectors etc
Tony
OK am a bit confused (not unusual) those 'little rascals ' with fast road cams aren't going to outperform your 208 kit current power plant are they?
Jim
Sbd 208 has standard cams and standard pistons and bosch cream 214cc injectors , only way to get more power is to have pocketed pistons and high lift cams,  I've got accrilite 87mm race top pistons maxpeeding steel rods, bosch 380cc white giant injectors standard crank ,with the 208 taper throttle body's, I'm looking for hydraulic cams just because of the cost in changing to solid lifters springs retainers etc, hoping for 220 to 230bhp.
Tony
You live and learn, I had misunderstood, so the 208 kit is essentially tapered throttle bodies, assuming you have the SBD designed (or similar) exhaust and an ECU controlling Fuelling and Ignition?
Jim
