NickBW Posted August 10, 2020 Posted August 10, 2020 Hi Looking for a GoPro 3.5 Mic adaptor to go in the westfield thanks
kevo2711 Posted August 10, 2020 Posted August 10, 2020 They’re not cheap! I ended up buying a new one for £50
Geoffrey Carter (Buttercup) Posted August 10, 2020 Posted August 10, 2020 I bought this and it works fine. 1
kevo2711 Posted August 10, 2020 Posted August 10, 2020 If you have anything from a 5 black or newer, the port changed so you’ve to use an expensive GoPro adapter.
NickBW Posted August 11, 2020 Author Posted August 11, 2020 9 hours ago, kevo2711 said: If you have anything from a 5 black or newer, the port changed so you’ve to use an expensive GoPro adapter. Yep, i need the expensive one now.. @kevo2711 and @Geoffrey Carter (Buttercup) . Do either of you run external mics in your cars? which mic do you have?
Geoffrey Carter (Buttercup) Posted August 11, 2020 Posted August 11, 2020 3 minutes ago, NickBW said: Yep, i need the expensive one now.. @kevo2711 and @Geoffrey Carter (Buttercup) . Do either of you run external mics in your cars? which mic do you have? I have two microphones. https://www.protastic.co.uk/spares-parts/324-clip-on-lapel-lavalier-microphone-with-35mm-jack-plug-689240628351.html http://www.rode.com/microphones/lavalier This is a video I took the other day with the cheap microphone attached.
