Westfield Aero Style fuel cap
I am looking for a fuel cap insert, has anyone got one they want to sell before I buy the full kit from Westfield.
I was hoping to pick one up from other suppliers but I have had 2 that don't fit.
I am not bothered whether it is a locking cap or not.
You have pm
Looks like you already have a couple of options but I'm thinking of changing my original WF silver one to a black one.
Full kit including two keys.
On 06/08/2020 at 19:17, matthew902 said:
https://www.ebay.co.uk/itm/262238386819
I believe there was a thread on here some time back that recommended this one, believe it was noted that it is shinier than the original.
That looks like it might be too small, I have messaged them for the cap diameter, I need 3"(76) that fits into a funnel with 4"(102mm).
22 hours ago, Wessex said:
You have pm
Thanks for the offer Malcolm but sadly too small.
Hi Tim, Do you have any measurements for yours?
Apparently mine is an earlier cap, I have no idea when they changed to the smaller one so the one in the Westfield shop is unlikely to fit anyway.
My car is a 94 model I believe.
I'm pretty sure mines 3" pcd 6 bolt mounting, 51mm to 57mm stepped fuel hose neck.
I'm surprised your filler is 3" to 4". Maybe you could use a hose for the step change.
Earlier Kit Bodywork, depending on car model, could have loads of differences around the tank/fuel pump/filler area, compared to current much simpler ZK’s.
Many of the non-full kit Zetec models, for instance, used an in tank pump, complex breather pipe/filler neck arrangement, often with carbon canister, and had a flushed in, vented, filler cap.
Unlike ZK’s, which have an external pump, very basic external vent, with roll over valve, and a surface mount, non-vented cap.
The problem is the size/diameter of the mounting plate/ring If I use a smaller one the hole in the bodywork will be too big.
You are not wrong but I find this is true with most bits on our little cars, as you mentioned in another thread about valuing a Westfield "No 2 are the same"
I ordered a 3" cap from Burton Power that fitted the Hole but when locked it did not seat and you could move cap in and out about 5 mm. So it looks like I will have to send that back and order the same part but with the flange.
https://www.burtonpower.com/aero-fuel-filler-cap-3-cap-8-hole-x-4-pcd-flange-moccap2.html  @ £79.90 incl VAT.
This looks like the same item Made by Newton Equipment.
https://www.merlinmotorsport.co.uk/p/flush-fitting-fuel-cap-120mm-diameter-cap2 @ £98.27 incl VAT
Burtons Part is listed as a Mocal Aeroquip product but the cap they sent me had a label for Think Automotive Ltd But was in a Newton Equipment box.
Thats some multi tier distribution. I bet the part only costs £1 to make. lol
