TableLeg Posted August 4, 2020 Posted August 4, 2020 IVA compatible Wing mirrors. Bought from Furore and only used for IVA test. £15 plus postage Stainless Steel bond in M6 threaded fixings NEW £10 plus postage NGK BCPR5EIX-11 Iridium plugs NEW £10 for 4. Plus postage
TableLeg Posted August 4, 2020 Author Posted August 4, 2020 Alternator pulley 6v 48mm 17mm bore NEW £15 plus postage Alternator pulley 6v 62mm 17mm bore NEW £15 plus postage Standard Westfield IVA compatible steering wheel and standard Westfield column. Steering wheel is a bit tatty. Column is as NEW renoved after IVA. £50 plus postage or to split £20 for steering wheel/hub and £30 for the column (plus postage). Pair of new Black sliding pins with recessed plates. With fixing pins although they have been shortened to a thread length of 70mm. These cost me £20. £8 plus postage. Pair of Westfield supplied LHD Dominator headlamps. Zero miles as were fitted for IVA which subsequently failed due to them being LHD ones. Could be the basis for a modified set of LED headlamps or new bowls fir old/damaged Domintors. £40 plus postage. Please note these have LHD lenses....
NickBW Posted August 4, 2020 Posted August 4, 2020 The serial to usb. Will that work on the ones 600 if so I will have that if it's available please.
TableLeg Posted August 4, 2020 Author Posted August 4, 2020 1 minute ago, NickBW said: The serial to usb. Will that work on the ones 600 if so I will have that if it's available please. Sorry Nick I have no idea. It is a generic USB to RS232 adapter.
NickBW Posted August 4, 2020 Posted August 4, 2020 Thanks. I will pass and look for a omex one to make sure. Thanks.
TableLeg Posted August 4, 2020 Author Posted August 4, 2020 33 minutes ago, Dazz150 said: I will have the USB If still available No problem. PM me and we'll take it from there.
TableLeg Posted August 5, 2020 Author Posted August 5, 2020 10 hours ago, NickBW said: Thanks. I will pass and look for a omex one to make sure. Thanks. No problem. 1
LoneWolf Posted August 5, 2020 Posted August 5, 2020 Sorry for the question not related to the sale, but I was wondering where those pulleys can be bought? Need a 5v for a similar Denso alternator I have. Thanks 😊
TableLeg Posted August 5, 2020 Author Posted August 5, 2020 5 hours ago, LoneWolf said: Sorry for the question not related to the sale, but I was wondering where those pulleys can be bought? Need a 5v for a similar Denso alternator I have. Thanks 😊 I imported all of mine from the US. Try Ebay.com 1
Craigib76 Posted August 7, 2020 Posted August 7, 2020 So these have the retaining pins too if so I will take them and the 2x switches if they are still available Craig
TableLeg Posted August 8, 2020 Author Posted August 8, 2020 10 hours ago, Craigib76 said: So these have the retaining pins too if so I will take them and the 2x switches if they are still available Craig Hi Craig, I do have the pins although they have been shortened a small amount. If you're interested PM me. Thanks.
Craigib76 Posted August 9, 2020 Posted August 9, 2020 hi i will take the 2 x switches not 100% sure the sliding pins will be quite long enough for what i need if you can send me your payment details i will sort it out cheers craig
