Lundy
C20XE Weber Throttle Bodies
Lundy
Weber 45DCOE throttle bodies with TPS which has a connector to suit MBE
Twin Throttle linkage
SB Developments manifold to suit 0 Degree engine orientation.
Fuel rail to suit Bosch 803 injectors
ITG JC50 foam Filter and backing plate
40mm trumpets a couple are a little scuffed around the rim.
Weber fuel pressure regulator marked at 2.5 Bar
These were fitted to a narrow body car and the filter base plate has been cut to suit.
£375
Collection from Pickering Near York welcome or could post
Share this post
Link to post
