Sierra propshaft
Michael Whitworth
I am in need of a Sierra propshaft or propshaft flange/yoke that bolts to the diff so I can have my current prop modified.
Has anyone got one kicking around that they don't need? A single Westfield one will do as long as it has the Sierra diff flange on it.
I don't know if they have different sizes so if you have one and can take measurements that would be handy to be sure.
TIA.
Mike
Link to comment
If you measure your flange I might be able to help. I have the larger flange spare
Link to comment
Hi Dave,
I think I have a propshaft sorted now but the dia of my diff flange on both diffs is 106.8mm. Each flange has 4 x 10mm and 4 x 8mm holes with no threads suggesting I will need nuts and bolts. Although till I get my prop I don't know if I will need 4 x m8 or 4 x m10. Or would it have originally had 7/16 and/or 5/16 bolts? UNC or UNF.
Note for admin, should I move this to my other thread about the diff conversion?
Link to comment
This is a Sierra Diff., The car had the Westfield Alloy Casing with English Diff.
Link to comment
