1700 Crossflow, Gearbox and Prop
Complete 1700 Crossflow Ford engine for sale. Available due to bike engine conversion. Originally Built by Rallytune in Lancashire.
Engine Parts include:
  • Duplex timing gear and chain
  • Reground cam stamped 44 on the end journal so believed to be equivalent of Kent 244 cam, but I have no documentation or proof of this
  • Steel Rocker posts
  • Baffled alloy sump
  • Twin 40 DCOE Webers including air filters and new Magard duel cable thottle linkage
  • Lumenition electronic ignition and coil
  • Offset distributor
  • Tubular steel manifold
  • Stainless steel exhaust with allloy heat shield– believed to be Westfield
  • Alternator
  • Brand new starter motor
  • Engine mounts
  • New water pump
  • New radiator fan switch
Price of engine complete to spec above: £2000
Gearbox by separate negotiation
Ford Type E “Rocket “ gearbox. Nice slick gearchange and fresh oil. Never used by me in the car but all seems in good order:
Price £375 price reduced to £200
Prop shaft by separate negotiatio - almost new propshaft to suit with English diff flange - was fitted with the engine and rocket box in pre-lit chassis
Price £125
All prices negotiable(within reason)
Contact: Richard Vaughan 07388 124361
Engine situated near Bingley, West Yorkshire
I'd put this up for sale on classic Ford sites like Cortina Escort Anglia they can't get enough crossflows....
Thanks Geezer, I'll do that!
I doubt that will hang around long mate - looks very nice. A lot of worn out rubbish on e-bay from time to time so IMHO good stuff will start to go for a premium soon.
Any idea waht the bhp output was - I'd be guessing 140 - 150 at the f/wheel?
Good luck with the sale - doubt youll need it though!
Mart.
Thanks Mart
I've no idea what the output is but in theory, based on the spec it should be good for 135ish.
I'm happy to sell certain parts separately:
Engine Only to include:
Steel Rocker posts
Baffled alloy sump
Offset distributor
Alternator
New water pump
Price of engine complete to spec above: £1800
Tubular steel manifold - £75 + postage
Stainless steel exhaust with alloy heat shield – believed to be Westfield - £125 + postage
Ford Type E “Rocket “ gearbox. Nice slick gear change and fresh oil. Never used by me in the car but all seems in good order:
Prop shaft by separate negotiation - almost new propshaft to suit with English diff flange - was fitted with the engine and rocket box in pre-lit chassis. I believe this will also fit Type 9 gearboxes.
Price £125 + postage
I've dropped the price of the Rocket box to £200 it was a bit high at £375!!
Rich
Would you sell the sump separately, if so how much please?
Hi Martyn, sorry but at present I'd rather sell with sump complete as it's then more desirable as a complete installation for a kit car.
If it hasn't moved in a few weeks I may take a different view.
Rich
All parts now sold apart from Propshaft and Webers. These are Twin 40 dcoe webers on crossflow aluminium inlet manifold. Fitted with new twin throttle cable linkage. the linkage has been installed in car run once to test engine and then removed along with carbs so not exactly "new" but near enough!. Includes new pair of filter socks too.
Jetted for 1700 crossflow.
Only £550 + postage ..
These are over £1100 new from Burtons!
PM me or e mail richvaughany@outlook.com
or better still mobile 07388 124361
  • 1 month later...
Hi do you still have prop shaft?
