MX5 'Donor Package'
Hi All,
Due to a change of plan, I now have the following, all from a MK1 1600, that I need to sell.
Engine with all ancillaries.
5 Speed gearbox.
ECU
Wiring loom, with most connections tagged.
Steering column with lock and 2 keys.
Complete rear subframe with diff, drive shafts, suspension, hubs and brakes.
Front hubs and brakes,.
Prop shaft
There are 4 x 14" alloys with tyres. They need a complete refurb. I would say the brakes are only any good for exchange.
Looking at average prices on ebay they should make around £750. I need the space for incoming parts so £500 collected from Buckingham.
Regards
Gary
Open diff or LSD? Do you know the ratio?
Hi Russ,
I don't know the answer to that. It's still mounted in the subframe, do you know if there's a way I can find out?
Gary
The ratio can be done by turning the input and counting the outputs but to tell what type of diff it is you will need to remove the drive shafts.
14 hours ago, garytipping said:
Hi Russ,
Gary
if it has bolt on shafts I should be able to tell you if you can post sone clear pictures of the “ears” on the driveshaft mounting flanges.
Thanks Mark, off to the garage shortly, so I'll try and get a decent photo.
cheers
Gary
Hi , Here are some photos of the MX5 diff.
I've put the subframe on axle stands and rotated the wheels, they both rotate in the same direction. Looking on line and comparing pictures of the 'ears' it appears to be a Viscous limited slip diff. 5AE3E682-DD5B-44FE-8902-5690B6CA1A04.thumb.jpg.41278b3368e2fb67f3f5ee24e64ac8a9.jpg
I've also marked a wheel and the output shaft and rotated the wheel. I would appear this is a 3.6 diff, which I read is rare.
As you can see, these are exactly how they came out of the MX5!
hope this helps.
cheers
Gary
Looking at the ears it appears to be a 6.5” CWP Viscous VLSD. These were only fitted to the 1.6 up to about 1993 so most likely a 4.3 ratio.
Thanks Mark, I was just turning the road wheel and counting the revs of the output shaft, seemed to be under 4.
On 09/07/2020 at 21:49, Mark (smokey mow) said:
19 hours ago, Mark (smokey mow) said:
It's a Viscous Limited Slip Diff. turning the road wheel and counting the revs of the output shaft it is under 4.
let me know if you need any other info.
Regards
Gary
Ratios would be either 3.6, 3.9, 4.1 or 4.3.
the 4.3 was only used on the Mk1 1.6 diff Up to 1993 which is characterised by the larger rubber damper on the prop shaft flange.
From 1994 the 1.8 used the larger 7” diff with a 4.1 ratio and then when the detuned 1.6 came out in 1995 this likewise used the same diff. The mk1 diffs had bolt on shafts Whereas from the Mk2 These were push in shafts.
the 3.6 and 3.9 ratio were only used in the cars with 6-speed gearboxes and again used the 7” case with push in shafts.
Lots of diff info :) probably not what I need though
Don't you need an engine? Rather than a diff
  • Haha 1
I don’t know yet, I’ve been I’ll in bed all day :( A wise man told me he thinks it isn’t bottom end. I’m inclined to check the water pump.
No I said it isn’t top end 😛
