etypebernard Posted July 8, 2020 Posted July 8, 2020 Sump for 2.0 Zetec was to be fitted to my Silver Top but changed plans. I believe this is an old stock Retro Ford Rear Tank (still stock new gaskets) unit complete with drain plug, dip stick ,strengthening rails and pick up pipe. When fitted it was flush with my Ford Bellhousing at the bottom and cleared the passenger side starter motor. The front and rear additional fixings are needed to be made into the oil pump casting and rear seal holder which is best done with the engine out. £75 plus £10 postage to normal UK destinations.
