Brian James Minno Twin Axle Trailer - SOLD SOLD SOLD
The time has come to sell my Brian James Minno Trailer.
This is an ideal trailer for a Westfield, and the bonus is it will fit inside a single garage.
I have owned it for three years and it has been faultless. It tows really well.
It comes complete with:-
Manual Winch which works fine
Hitch Lock and padlock
Galavanised box and padlock, I had this bolted onto the A-Frame and it just needs bolting back on again. When in position a standard widebody Westfield will fit on without clashing on the box.
A full set of 3" ratchet straps and wheel straps.
Trailer Spec is:-
Brian James Minno Twin Axle.
1380kg Gross Weight
375kg Unladen Weight
1005kg Maximum Load Weight
700kg Maximum load per axle.
Whilst I have had it I have:-
Upgraded all four tyres with new ones, the tyres are 500kg rated so more than up to the job.
I upgraded all of the rear lights to LED's (including Foglamp). I have also added LED position lights to all four corners of the trailer
I have widened the bed of the trailer by about 60mm. Basically what has been done is to unbolt the two wheel beds from the frame and then reposition them 30mm wider on each side. This means no wheel rubbing on the side of the beds when loading or unloading a wide body Westfield.
Some general photos of the trailer below:-
There is everything there you need to simply drive your Westfield onto it, strap it down and tow it immediately. All you need to add is a rear number plate of your tow barge registration number.
It is currently in Banbury, OX16 postcode
I am looking for £1300 for the job lot.
Gary
SOLD
