Arm Posted June 16, 2020 Posted June 16, 2020 Anyone fitted or tried the Bafang mid drive kit ? I keep coming back and looking at the bbshd version. The 1000 w motor. Strictly off road mountain biking. Thoughts please Quote
Blatman Posted June 16, 2020 Posted June 16, 2020 9 hours ago, Arm said: Thoughts please I think... . . . . . . . . . . . . . . . ... you're too old... Quote
Mike Rowland - Essex AO Posted June 16, 2020 Posted June 16, 2020 I tried the 350W Bafang mid-drive kit. I ended up going with a hub motor instead, as that felt more natural to me - I found the mid-drive a little slow to ease off the assistance when changing gears, so they were given a bit of a pounding. I have found that the controller is the most important bit - cheap ones just race up to the speed limit and then cut out, so you tend to find the gears a bit irrelevant as you always get pushed up towards the top speed. I found a CycleAnalyst controller worth every penny, as you can fit a separate power (current) limit and throttle rather than a speed limit which feels much more natural. Quote
Stuart Posted June 16, 2020 Posted June 16, 2020 My 250w motor will take me to 17.5mph on my not-so-light Specialised hybrid. Does that mean 1000w will take you to 70? Quote
Blatman Posted June 16, 2020 Posted June 16, 2020 8 minutes ago, Arm said: At least it permits retirement Now you're just showing off... Quote
Blatman Posted June 16, 2020 Posted June 16, 2020 6 minutes ago, Stuart said: My 250w motor will take me to 17.5mph on my not-so-light Specialised hybrid. Does that mean 1000w will take you to 70? Arm's at least 90... Quote
pistonbroke Posted June 16, 2020 Posted June 16, 2020 Don't know if this helps but I found it interesting Quote
Dibby Posted June 17, 2020 Posted June 17, 2020 I'd be more inclined to buy an electric bike than a bolt on. Reports that the way they interact with your pedalling effort and gears aren't great. 1000W on a bike sounds crazy, pro racers can hold just over 400W on climbs. Just bought the wife an electric hardtail so we can ride together and with a 250W motor, she gives me a right good beasting on the climbs. Quote
Dibby Posted June 17, 2020 Posted June 17, 2020 8 hours ago, Stuart said: My 250w motor will take me to 17.5mph on my not-so-light Specialised hybrid. Does that mean 1000w will take you to 70? When the warranty runs out, the speed sensor is easy to frig and they will do an awful lot more Quote
Jim cunliffe Posted June 17, 2020 Posted June 17, 2020 25 minutes ago, Dibby said: When the warranty runs out, the speed sensor is easy to frig and they will do an awful lot more How do I “frig” a Bosch motor ? It’s frustrating to be limited to 16 mph , Quote
Stuart Posted June 17, 2020 Posted June 17, 2020 39 minutes ago, Dibby said: When the warranty runs out, the speed sensor is easy to frig and they will do an awful lot more Dibby it's a rear hub kit I fitted to my own bike so all I have to do is change the wheel size in the settings to get more speed. But works good for me as is. Quote
Dibby Posted June 17, 2020 Posted June 17, 2020 31 minutes ago, Jim cunliffe said: How do I “frig” a Bosch motor ? It’s frustrating to be limited to 16 mph , The Bosch is a plugin dongle if you Google how to remove the speed limiter from a Bosch E-bike motor. They don't half go, used to get overtaken on the daily commute by a bloke on a derestricted ebike. It was all I could do to slipstream him for a minute Quote
