Air Filter for Zetec
Hi All,
I'm after a new air filter like this:
This is an original Dunnell but as you may note, it's upside down in that the Dzus connectors are on the bottom if the writing was visible - this is because it won't clear the fuel rail so is fitted upside down. So, anything without writing on will of course work just fine as will something more rounded i.e. not as squared off as mine. The white marks and torn foam are where it has rubbed against the tub over the years.
Overall dimensions are:
  • Height: 5 ¾ inches
  • Width: 17 inches
  • Depth: 4 ¾ inches
Any higher and I’ll struggle to fit it as it’s already only a few millimetres from the bodywork. Slightly wider and deeper should be okay; if it’s shallower or very rounded though, I might struggle to get it over the trumpets.
Let me know what you've got please.
Thanks.
I have one the same as yours but it's brand new
Ooh. 👍 Are you selling, is it unbranded and if not is it the right way up for me?
I will get a picture in a minute for you
Ah, thank you. Sadly the writing will be upside down for my config and (I know it's my fault for not putting up measurements - I've done that now) it looks shallower too. I've not yet worked out to take these apart without destroying them so I'll pass on this one.
Thank you for looking and for posting 👍
I will have a look at taking it apart for you
Hi andy. If you need very specific measurements and no lettering you will have to go for a custom order from ITG without branding.
Im like you and when my filters start to fall appart, i search online for a cheap-ish used deal (but i have far much more room to play)...
They are around 100 quid, and probably not worth the hassle on trying to fit something else than the correct one.
On the other hand... is it visible as you seem to suggest the height is important to save the bodywork... If is not, why the branding position is so important?
Yeah it's visible Maurici, there is a similarly sized hole in my bonnet as it won't all fit inside. Branding not important at all, but upside down branding would be a bad thing. I guess something smaller as long as it covers the trumpets would be fine; need to measure trumpets and do a little more research in that one.
Thank you but please don't break it just for me 😧 - I'll get some measurements of the trumpets in a bit, that way we can tell if there is chance it will fit if indeed it can be turned upside down 👍
Yeah... when i meant branding i meant the writing itself upside down...
I gess im less picky as mines allways seen to be upside down.
