Tim Reid Posted May 25, 2020 Posted May 25, 2020 I was going to use this for a tidy panel mounted connector for a battery charger. I was going to cut off the male end to connect to the charger then mount the female panel mount on the dash connected to the battery. I ended up doing it another way so this is available still brand new. £12 inc mainland postage.
Si.Dalziel Posted May 25, 2020 Posted May 25, 2020 57 minutes ago, Tim (TimDave25) - Joint Thames Valley AO said: I was going to use this for a tidy panel mounted connector for a battery charger. I was going to cut off the male end to connect to the charger then mount the female panel mount on the dash connected to the battery. I ended up doing it another way so this is available still brand new. £12 inc mainland postage. just the job I’m looking to do. I will take it if it’s available thanks
