Paul T Posted May 22, 2020 Posted May 22, 2020 Bit of a clear out after re-doing my steering setup 2 x 6 hole Billet ally spacers and a crushable spacer left over from a boss I dismantled. 1 x 12.5mm spacer (new) has 6x70mm and 6x74mm PCD threaded M5 holes and 2 sets matching 6mm counterbored clearance holes making it totally flexible as an adaptor - also comes with 6 x M6 cap head screws. 1 x 35mm spacer (used and re-drilled/tapped to 74mm so can be used for both 70 and 74mm PCD wheels) has M6 c/bore clearance holes at 74mm PCD. £7.50 each posted or both for £10 And a collapsible steel spacer which was part of an old mount, had 6x70mm PCD threaded holes and 4 x ~68.5 PCD M6 tapped on the other end. This is free (buyer pays postage) or happy to include for £1 extra postage with the above.
