1960dave Posted May 10, 2020 Posted May 10, 2020 Has anyone got a ECU for a 2.o zetec with standard injection for sale? Maybe someone who has upgraded to throttle bodies.
Alfascozzesi Posted May 10, 2020 Posted May 10, 2020 I will have an ST170 ecu spare when I get off the car. Not sure if this would work for you or not? Just thinking it had VVT whereas the normal zetec won’t. Not an expert but if you think it would work then let me know.
Kingster Posted May 10, 2020 Posted May 10, 2020 6 hours ago, Alfascozzesi said: I will have an ST170 ecu spare when I get off the car. Not sure if this would work for you or not? Just thinking it had VVT whereas the normal zetec won’t. Not an expert but if you think it would work then let me know. Won’t work - as you say the VVT makes it a very different ECU altogether. Pretty sure you need to do bit of tinkering to get std ECU to work anyway - lots of info on Locost site about it
Wowblaauw Posted May 11, 2020 Posted May 11, 2020 There’s one on flea bay right now item number 333595811680
etypebernard Posted May 11, 2020 Posted May 11, 2020 I have one which is for an early Zetec engine ie pre electronic key. If you are interested I can get ref number. I purchase it but never used it so it is not tested by me.
