Rear arch stone protectors (kit fixed arch)
14 minutes ago, Martin Rice (Sparkymart) - Cornwall AO said:
Geoffrey  are your arches  fixed, Or are they fixed and painted to look  like detachable?  If they  are fixed  any  chance  you could  measure how wide they are .
Cheers  Martin
I have kit bodywork and the arches are fixed but painted black.
I have hooked the tape measure over the edge of the tub inside the cockpit area. I can get better pictures tomorrow in the daylight if you want them.
Try measuring them, mine are 9" at top dead center to the body line. That's What Patrick at west field measured one of there cars at the same.
Thanks Geoffrey, I'll measure up mine  tomorrow when I get home from work. I think I can make out where you've measured yours from I will update tomorrow 👍
Following with great interest.  I too have the Kit bodywork with fixed rear arches, and three Stoneleighs ago I bought a pair of ZK bodywork arch protectors from the Westfield stand, but after quickly testing them on my car I had to return them as they were too wide.  If the FW version fits, I'd be in like Flynn 😄
BTW, CarbonNV doesn't have a version for the Kit bodywork either, although he did offer to make some if he could have my car for a long period of time so he could make moulds for them.  But I haven't spoken to Mark since beginning of last year though, so not sure how much has changed.
I just made these for my fixed arch bodywork:
Mick cooper laid the prepreg 1mm sheet for me and I cut to shape
Like Quinten, I too am following with interest as I also have a fixed arch car with kit bodywork. I currently have no protectors fitted and would like to get some on before it goes on the road. 👍
Hi all i am also looking for a set for my kit bodywork. If there is enough interest perhaps we could get some one to make them.
28 minutes ago, Martin Rice (Sparkymart) - Cornwall AO said:
@Geoffrey Carter (Buttercup)
I've had a measure and from the lip to the outside of the wheel arch is just under 10"
We appear to be the same or within millimetres. is it worth you messaging Mark at Carbon NV for measurements of his arches.
Hi Geoffrey
Can you confirm where you purchased your arch protectors from please and which model they are classed for.
Might just bit the bullet and see.
Mark
27 minutes ago, Markfry123 said:
Hi Geoffrey
Mark
I bought mine from Carbonmods but they no longer supply them.
My initial post was because when I purchased mine they where not specified for "kit" bodywork. I just told them that I had a SeW model and they stated that they would fit.
I just thought that it may be worth giving the suppliers a ring to see if they would fit.
I went through this last year, carbon mods used to make some that did fit the fixed arch but no longer does westfield parts.
As i couldn't get any which would fit i ended up buying some for a detachable arch and trim down to fit.
Fixed them with tiger seal they aren't perfect but look better than a peppered arch 😂
They look pretty good did you only have to trim the inside edge. Does the outside profile match the arch many thanks.
Hi all
Carbon stone chip arches arrived from Westfield to day, you guessed it, they sure don't fit my car, not even close, even though I gave Westfield all my details for the original body purchase and spoke to them on the phone.
Oh well back to the drawing board, will see what Westfield come back with.
Well worth a measure up and see what your arch size is compared to my detachable arche area, they are also a slightly different shape.
My Body kit was quote 0000002029    SEiW BDYD SEIW Body work-Detachable arch  FW
Exterior panel pair-SEiW
