Rear arch stone protectors (kit fixed arch)
As above looking for a pair of rear arch stone guards  for the kit body work wit standard  fixed arches
Thanks Martin
Westfield had Carbon effect ones on offer £85 delivered, I think I just bought the last pair, but worth a phone call.
Toybox Cars also sell them.
Thanks Mike . I did look on the Westfield website  but couldn't see any for the kit body work  I'll  drop  them a line  if I cant find a second hand pair as I planned  on skinning them with  carbon fiber
Hi Martin,
Let me know if you have any luck, I have looked for a while now and had no luck.
What you running in the car? I have a 2ltr Zetec with was a squeeze as the engine sits so far forward,
Don't see many of the fixed arch Kit ones around.IMG_1545.thumb.JPG.e135329c2ef5e525f4445c9aa0408d21.JPGIMG_1546.thumb.JPG.71045a68da8581605a9a4db8616a3441.JPG
Just wondering if the ones that Carbon NV sell will fit.
I found the Westfield add on this site, in the suppliers forum, under still open.
5594071 FW stone guards £85 per kit including UK mainland shipping.
Got Westfield to check measurements for me aprox 9" wide at the top of the arch, not suitable for extra wide arch.
they should fit my FW body with removable arches.
ZX are definitely too wide for the Fixed arch Kit, I did consider buying a set and cutting them down in the hope that if I trim the edge which adjoins the body the profile of the arch itself would be the same.
Would rather find an old second hand cheap set to test first though.
1 hour ago, Markfry123 said:
Hi Martin,
Hi Mark I'm also running 2ltr zetec on 45's. I think mine  is a fairly early  one  as I don't  have any location blocks  for the bonnet
Yeah I saw that add but like Mark said  i think they might be to big and i really  wanted carbon. Hence  looking  for a pair i can modify and skin in carbon as I don't  think anybody make carbon ones for the kit fixed arch
Why I wasn't sure if they would fit is the fact that mine is Kit bodywork and when I bought mine they where not advertised as for kit bodywork and they fitted.
All I knew at the time was that I had a SeW. I didnt get them from Carbon NV though.
HI Geoffrey
I think the issue is that we have fixed rear arches, yours looks to have detachable arches.
Just now, Markfry123 said:
HI Geoffrey
Mine are fixed, they are just painted black.
Geoffrey  are your arches  fixed, Or are they fixed and painted to look  like detachable?  If they  are fixed  any  chance  you could  measure how wide they are .
Cheers  Martin
wow, they look good.
I thought I tried a set at the Kit Car show last year and they were too wide?, perhaps I am wrong.
Just to confirm what are the ones you have and where did you get them from.
Mark (Martin, hope you don't mind my notes on your post)
No worries  Mark  it would  be good to finally find out if the two body type  arches  are the same
