After a few years of ownership I have finally got round to fitting a 12v power outlet and hire wiring my eeeeemmm ‘safe device’ as I have wired it directly to the battery I have wired in a led switch to prevent leaving things turn on, I’m pretty pleased with the results in my homemade centre console! I just have to pluck up the courage to attempt to wire the start button next!!!
  • Like 7
Hi Wayne, this may help:
You don't need to do all of it if you just want to add the start button for example.
Thanks Ian I’ll have a look through that
I've removed my cigarette lighter type power outlet over the winter and fitted a twin USB one instead,as majority of things you need to charge now dont have cigarette lighter type plugs on them!🤷‍♂️
Yes that makes sense In hindsight I probably should have done that! Although I can always change it at a later date
 Yeah now you've got the wiring there and the hole in the dash it's only a little job👍
