Matt_S Posted April 16, 2020 Posted April 16, 2020 After some gates barricade fuel injection hose 1/4” (6.3’mm ID) diameter about 12 inches worth to finish my fuel set up. TIA
Si.Dalziel Posted April 17, 2020 Posted April 17, 2020 20 hours ago, Matt_S said: After some gates barricade fuel injection hose 1/4” (6.3’mm ID) diameter about 12 inches worth to finish my fuel set up. TIA Your best bet will be eBay Or amazon I reckon. Unless someone local has a spare bit
Dave Eastwood (Gadgetman) Posted April 17, 2020 Posted April 17, 2020 1/4”? That sounds small? Are they not normally circa 8mm bore? (5/16”)
Dave Eastwood (Gadgetman) Posted April 17, 2020 Posted April 17, 2020 PS, if 5/16” injection Barricade will do, let me know and I’ll post you some out!
Matt_S Posted April 19, 2020 Author Posted April 19, 2020 It’s for my return from the swirl pot to my main tank, I used a smaller pipe to reduce the flow.
Dave Eastwood (Gadgetman) Posted April 19, 2020 Posted April 19, 2020 Normal practice is to use a restrictor, which blocks it even more. The problem with doing it with a hose, is two fold, it might Not actually restrict it enough, and more practically, you’re now stuck with three different sizes of hose on the system, making life complicated for yourself, especially if you needed to do field repairs if you had a damaged hose.
