Innovate lm2 wideband
wizzer
I have Tony, Andy had put his name on it but not heard from him for a while, it needs a lambda sensor it burnt out towing your car😁😁.
I will contact him see if he still wants it if your interested.
Steve
Link to comment
15 minutes ago, Chris King - Webmaster and Joint North East AO said:
Thanks for the link Steve just ordered one 😁
Which one have you ordered,
Not sure what i want to go for yet, I didn't really want a gauge on the dash that's the reason I was looking at the lm2,
Tony
Link to comment
Lc2 - plan to wire into my DTA ECU as it can send readings via can to my aim dash.
Have had a long standing cold start mapping issue and a bit too much “asbo” behaviour off throttle that I’d like to tweak out so the wide band will help with that.
Link to comment
Done exactly that Chris. LC2 into DTA, Can link into AiM dash.
Have a “mapping” screen on the dash, with as well as the usual T’s and  P’s, RPM, TPS and AFR.
The ECU can also log the AFR readings for back-at-home analysis, too.
Link to comment
:d They are I good price, I didn't realise quite how "cheap" they are.
One left now and it's got my name on it!
Link to comment
Tony
No need to mount the gauge in the dash. Make a  little case up for it so that you can use it remotely as a display in the garage.
Or if you have a free analogue channel on your Dash 2 run the 0-5V output to it and display the readout there.
Link to comment
Thanks Steve
I have got one channel left on the dash 2  I've been looking for info to see if I could display it there  but couldn't find anything, will there be a option for it or will I have to calibrate the dash, if your going for that last one I'll get mine from tweeks it's got an option for a shorter cable.
Thanks Tony
Link to comment
2 hours ago, wizzer said:
Thanks Steve
Thanks Tony
Tony,  the Dash2 looks for a 0-5v input and you can scale the ouput (display) against the input v. the output v from the lambda controller is linear so it's easy enough to do. Spartan one looks good, doesn't seem to have a lot of the features of the Innovate but if all you need is a 0-5v output then ideal. If you want the Innovate help yourself. I've found the same at £160 elsewhere. According to Innovate you can shorten the lead if needed.
Steve.
Link to comment
