Dash panel *Found* closed
sorted, thanks all!
After the dash panel insert (where the gauges would actually sit) for a wide. Any age/condition, even if only a template for me etc.
Pete
If you mean the contour dash insert, I’ve always just made my own. All it needs to be is a flat panel with openings cut in, can either be painted, vinyl wrapped, or you could carbon wrap it.
this was a sheet of aluminium, cut out for switches, gauges etc, with 3 Carbon film on it.
That was actually the second version I did, first for IVA, was simpler, with stock switches, and just covered with vinyl.
looks nice, no I meant the whole dash. Perhaps insert was wrong term to use :)
In that case, you just want a dash, nothing more complicated than that!
Hi, I've got a Dash And Crash pad for a wide body. Will take a pic and send it to you. I bought it for the gauges and switches as I have a narrow .
Pics of Dash, crash pad and both together. £65 plus P&P. Excludes all switches and instruments. 8
Thanks, what were the 3 smaller holes on the left for? Heater?
12 v accessory sockets.
