in a quick bullet point format, what roughtly do you need to go from a standard car to one that will be albe to have ago at the snetterton round?
something like
forget the  more power/handling mods......
approved  roll bar.  Half or is full required?
approved in date seat and harness.?
plumbed in fire extinguisher?
approved helmet and overalls?
kill switch. ?
just looking to have a bit of fun, ... not go full balls competitive in...       he says :)
you do not need a fire extinguisher
you need approved gloves
Seat harnesses or belts do not need to be in date
Kill switch is required
Helmet might require HANS device if using slick tyres and type of roll bar or cage depends on tyres/class entered due to car spec
Am I right I’m saying that a basic ignition switch (with an “on - off” position marker label) is sufficient?
Yep so long as it has a marker label
oh thats great.. best i get reading.. the beginners guide
i assume containes  the simple requirement regs for road going car , if not link would be appreciated
Depending on your location, a current competitor may be able to pop round and give you an easy list of thing to consider, If running in road going spect a westfield in its simplest form needs little changes to be able to compete.
The biggest outlay will be your own PPE and roll over protection dependant on what you have already.
