AdamHolmes Posted March 8, 2020 Posted March 8, 2020 SOLD SOLD SOLD This kit has never been fitted and just sat in its box, project i purchased them for no longer going to processed with. Kit cost £605 looking for £400 delivered to any UK address Link - https://www.ebay.co.uk/itm/Wilwood-Escort-Mk2-English-Axle-Only-Rear-Brake-Powerlite-Handbrake-Kit-/231932235331 Application: Escort Mk1 and 2 Rear Axle on lightweight car application (maximum vehicle weight 750Kg). Suitable for the ENGLISH axle, can also be fitted to the ATLAS with some modifications. Caliper Type: Powerlite 4-Pot Hand Brake Caliper Radial Mounted Caliper With Integral Cable Hand Brake System Disc Size (Diam x Width): 240 x 10mm Minimum Wheel Size: 13 inch Produced by the drop forging process to ensure a stiff low deflection body but at a lighter weight - approximately 2lbs (1kg). The Powerlite caliper features the Wilwood Squeal Reduction System (SRS) eliminating bridge wear caused by pad gouging and reducing the annoying '4-pot squeal'. Also incorporating the now well proven fast pad change clip (patent under consideration). Solid plain discs. Cables & Pads not included
