Standard m16 to Westfield hs caliper
Swapping from the standard M16 to Westfield hs front calipers is the brake hose just shift from one to the other or they different?
When I did the same swap I had to buy new flexi hoses.  The hose screws in vertically instead of horizontally on the M16. Will depend on how much slack you have.  If using the original hoses, make sure their is no strain on them with the steering on full lock.
