Ford English Aluminium Diff Housing
But of a long shot, but as par title....
...if anyone has a ford english ali diff housing lurking unloved for sensible money.
Daniel
Always best to buy a new one. SPC components in Redditch sell them. If theres one for sale second hand, you have to ask why given that they are desirable. Most likely its got a problem
Valid points, as I say, going to be a long-shot!
This place presumably?
https://www.tracsport.com/english-axle
Tracsport Diff Housing English Alloy L169       £358.64 ex.VAT
Tracsport Magnesium Diff Housing                  £478.19 ex.VAT
Daniel
yes
keep fancying one of these myself but seem to hear mixed reviews about them.
Are these the ones to go for?
Wonder if they would do a discount for 2 :suspect:
I am in two minds too.
Obviously its very real weight saving, like 5kg of unsprung mass, but equally the car drives well and does all I need without it.
Clearly a damaged/problematic one could be a world of pain but otherwise it should be a fairly straight swap with no downside?
Years ago I missed on going for a very good price, and have always wondered if it was a error on my part or a blessing!
Ended up with a 4.4:1 ratio when I put in the ATB and it doesnt meet my needs at all, hence rebuild time.
Daniel
Ive had one in the past but it fractured but then again I was sprinting with quite brutal starts and dog gearbox changes with a good amount of power. I replaced it with a lightweight cast iron one from a 105E which is a better option for what I was doing with it. I might still have one if of interest
This is my dilemma too
Diff needs a rebuild and going to change the ratio at the same time so cant decide weather to take the plunge.
Probably not worth a lot in performance really but every little helps and we like shiny new things.
John. Will let dhutch take you up on your offer if he wants to as its his add. I have just hijacked it. :blush:
That is very interesting.
If there is risk of fracture (presumably fatigue failure) on the Ali ones that does put me right off.
The car is being fitted with a stock 2l blacktop, and I run list 1a tyres, fast road use and autotesting so less harsh than a lot of sprint usage would be, but also driven hard including a reasonable number of quick starts.
Presumably the 105E had an English Axle in it, with a reduced weight diff housing? Direct fit part? Will have to look at that.
Daniel
Daniel
Yes 105E was English and thinner walled cast iron. About half the weight saving of the aluminium one
This!
Thank you for your consideration, I will PM John and report back.
Daniel
One with an ATB diff has come up for sale from Blatman.
Thanks, although if you are thinking of the below, its not the part I am after, my car is a live-rear using the whole of the English axle not just the diff in a IRS setup.
https://forum.wscc.co.uk/forum/topic/137835-44-english-diff-with-quaife-atb/
Daniel
