Westfield SE Wide Body - 2.0L Zetec Blacktop. (2006) -WITHDRAWN
No longer available as I decided to keep and spend a fortune on it !
Basic Spec
·        Westfield SE Widebody in Yellow
·        Brand new  2.0L Zetec Blacktop engine.
·        Running on Twin Weber 45’s + Alpha 1D Ignition System
·        MT75 Gear Box with Short Shifter.
·        4x Point Harnesses
·        Very quick car with beautiful noise.
·        First Registered: 26 07 2006 (Q Plate)
·        5 Former owners, but I have owned the car since July 2015 (approaching 5 years)
·        I have spent a small fortune on this car in the 5 years of ownership (read below) (£3.5k spent)
·        Mileage: ~10,600 miles (I bought it with 9,200 miles)
·        MOT: Until April 2020 (Happy to renew this as part of sale)
·        All MOTs available and a ring binder full of receipts and invoices. No expense has been spared.
General History:
·        Receipts show the original kit was bought in 2001 with eventual build completion & registration in 2006. (A long time!)
·        Originally fitted with Pinto Engine but this was changed for 1.8L Ford Silvertop engine.
·        When I bought the car it had this engine fitted, but was smoking on wide throttle.
·        I bought it as a mini project car with the intention of ‘fixing the engine’
·        I used the car for the summer of 2015 as it was and then took it off the road under a SORN (2016-2018) as I started investigating the engine problem.
·        The smoking engine was low on compression on all 4 cylinders so after removing and stripping the head, all 4 cylinders liners were found to be scored.
·        As expected – It was burning oil.
·        At this point I decided to ditch the engine and start a fresh.
·        Then one thing lead to another and OCD has taken over.
General Condition:
Underhood.
·        Brand new Ford 2.0L Zetec Blacktop fitted engine (less than 200 miles ago)
·        Brand new Clutch
·        Brand new Flywheel
·        Brand new Denso 40A Alternator + Serpentine belts.
·        Brand new foam filter for carbs
·        Reconditioned Radiator (stripped, cleaned repainted)
·        Reconditioned Steering rack (Stripped, re-greased, repainted + bushes)
·        Brand new steering tie rods.
·        New Gaskets (Intake & Exhaust manifolds)
·        New Catch Tank Fitted with machined aluminium billet bracket.
·        All fasteners replaced with stainless steel bolts/ nuts/washers.
·        All assembly torques recorded during re-assembly
·        Front end chassis – Repainted.
·        Carburettors re-gasketed & rebalanced professionally at BD Engineering.
·        Coolant hoses are original ones. Nothing 'wrong' them but could do with new ones to match otherwise gleaming underhood environment.
Other Mechanicals
·        Rear Differential was reconditioned in 2015 at a cost £800 just before I bought the car. (Receipt available)
·        Brake System remain as purchased – Discs at Front. Drums at rear. Work very well with no complaints.
Interior
·        Alcantara Momo racing steering wheel (with quick release)
·        Steel sheet / carbon effect vynal dash ditched (still available)
·        New Carbon Fibre Dashboard with brand new switch gear fitted (dials not changed)
·        Navy Blue seats and carpets remain. (As bought)
·        My plan was to ditch blue seats and replace both these and the carpets - which are a little tired. (Not a fan of blue interior)
·        I have replacement seats available (black with yellow piping) – in outstanding condition.
·        But have not got as far as buying the carpets – so the seats are not fitted but come with the car.
·        This was going to be the next phase of my interior restoration.
Bodywork
·        Yellow with Chrome theme (Headlamps, windscreen, wishbones + Springs)
·        Carbon Fibre ‘back shelf’
·        Generally, in excellent condition with a few minor knocks/chips but this should be expected for the age of the car.
·        Again my plan was to go through a de-chroming process, replacing Chrome with black powder coating ancillaries.
·        This would have been Phase 3 of my project.
Wheels & Tyres·
·        15” x 6.5 Alloy Wheels. (+Spare)
·        195 65 Tyres - in great condition.
Other Items:
·        Side Screens included.
The Bad Bits (Some will be addressed before sale)
·        Slight hesitation on fast right hand cornering - Car is booked into BD Engineering to fix. (This will be fixed for a prospective buyer)
·        Minor localised tear on the passenger seat (back). Plan was to replace both seats. Replacement seats available will be provided with the car.
·       Carpets 'ok' but generally a little tired.
No expense has been spared, and to be honest if circumstances were not different I would be continuing the phased refresh of this car.
I am a WSCC member and have been for several years. You will see some of my posts on here which will also give some of the live topics that I have sought help on during from front end restoration.
I will add more photos over the weeken.
Serious interest only please. I am under no desperation to sell the car so without the right price and the right home - I will not let it go.
Fadi (07951 258 465)
  • Kent Westfield changed the title to Westfield SE Wide Body - 2.0L Zetec Blacktop. (2006) -WITHDRAWN
