Sierra SDV rear uprights SOLD
Having a clearout.
Westfield Alloy Sierra SDV uprights, with Sierra bearing carriers and billet conversion plates to take disc brakes (90mm spacing, suited Golf mkIV calipers) also has drum brake hubs machined down to fit inside the usual Escort (front) 240mm discs. £200 for the lot plus post - I may split if they don't all go as a job lot.
Two lower steering columns, one to suit a Sierra upper with the triangular fitting and another to suit the more usual splined shaft. Will post pics and lengths later - £20 each + post.
Sierra push-in driveshafts. Std length (from a 2.0 petrol 1988 drum brake car). These were brought new 4 years ago and are in very good condition apart from one split boot. You can get stretchy boots to fix this for a few quid of eBay. £50 + post (pics to follow)
Hi Chris, I'm overseas at the mo, but I'd like to buy your Sierra splined lower steering shaft please.  I'll be in touch as soon as I'm back this weekend.  Cheers, Iain
No problem. I’ll get a pic up later.
They are both approx 83cm end to end.
Uprights and hubs now sold.
PM inbound....
Uprights and one column sold - still have the Sierra column (the one with with the triangular fitment)
