John Dolan - Wirral & North Wales AO Posted December 21, 2019 Posted December 21, 2019 Alternator wanted, as per title.
Kingster Posted December 21, 2019 Posted December 21, 2019 I have a standard ford model that was on an ST170 engine I had. Not sure if that would suit but you can have it for postage cost. 1
John Dolan - Wirral & North Wales AO Posted December 22, 2019 Author Posted December 22, 2019 Hi Chris, Thanks for the offer. Does the alternator have a part number so I can check that it’s ok? The one I have is either too big, or needs a different adjustment arm which means the belt won’t fit. These things are never easy. John.
Kingster Posted December 22, 2019 Posted December 22, 2019 I’ll have a look later today and post piccies.
Kingster Posted December 22, 2019 Posted December 22, 2019 Sorry not had a chance today will try again tomorrow!
Arm Posted December 23, 2019 Posted December 23, 2019 Fit a daihatsu Nippon denso instead. Bracket is easy enough to make.
Ricky_B Joint Kent AO Posted December 31, 2019 Posted December 31, 2019 Made this bracket for mind today, works well and simple to make. Your only get about 30mm of adjustment so make sure the belt fit snug to start with. I think it needs to be 1165mm long six V Good luck Rich
