Glen_I Posted January 4, 2004 Posted January 4, 2004 Hi , can anyone recommend a good inlet manifold to fit to 20XE running Dellortoes (do i need a 7 degree type for clearence or is this not the case, with or without water rail, not having heater if this makes a difference) Looked on SBD site but they dont list price QED one is around £90+ Glen. Quote
oioi Posted January 5, 2004 Posted January 5, 2004 the sbd one is £94.00 you will need water rail i have an S-type inlet manifold from SBD. The engine is mounted horizontally but the inlet manifold has two bends in to raise the carbs higher than its natural position (to avoid clashing with the chassis). the price for this isnt listed tho. my engine is possibly slightly lower than standard as it is dry sumped. OiOi Quote
