C20XE short engine. Omegas, steel rods etc. - SOLD
C20XE short engine, fresh rebore to 88mm.
New steel H pattern rods with ARP2000 bolts, 88mm Omega/SBD forged pistons with new piston rings.
Later crank which has been balanced with the journals lapped/polished (standard diameters).
Fresh Mahle tri metal, bearings.
New AutoMega oil pump.
New water pump.
ARP head stud kit.
Alloy front pulley.
New rear seal
Usable pair of belt pullies.
This engine was built up as a spare and hasn't been run. It did have a head bolted up to it but someone wanted that so you can see where the head gasket was but otherwise the deck surface is as good as new.
£950.
 Steves engines are always immaculate .
