2008 227HP Zetec SEIW - SOLD
Posted (edited)
For sale is my 2008 Westfield SEIW.
I have owned the car for just shy of 18 months, in which time I have used it on the road for sunny Sunday drives and completed less than 600 miles in that time. I had purchased it with the intention of doing track days but as I started karting again so I haven’t had the time or funds to do both and Karting has taken priority.
The car has a fast road/ track focused setup (corner weighted and balanced) and is immense fun to drive.
The car comes with 8 months MOT.
The oil, brake fluid, plugs, HT leads, filter, rocker cover gasket, grommets and water pump were changed around 1000 miles ago so it’s all set to go to a new home that will get to use it more than I have. If I had the time space and funds I would not be selling it.
The car was built by a previous member Anthony Noy. Who I am still in contact with, he changed the original engine for a focus ST170 full donor.  The tacho displays 8805 miles which is for the chassis but the new engine has now done around 3000, has a power output of 227bhp and weighs around 500KG in total - quite the weapon but very easy to handle.
There are some stone chips on the rear arches which I have cleaned up and covered with a carbon look wrap - easily removed if you prefer without - I liked the look and it protected the paint for not much cost. There is a little scratch on the N/S arch but its only small. Since owning the car I have also sorted out the driving position so its spot on now and really makes the car more comfortable and controllable.
The car comes with a LOAD of spares which are listed below.
The asking price for the car is £12,500 OVNO.
Please contact me (Andy) on 07545878460 if you would like to see the car
PS: The car currently has the windshield in place but I can switch it back for the new owner if preferred.
The specs of the car are:
Engine
Focus ST170 Engine
Twin Webber Carbs
Pipercross Air Filter
Raceline Sump
ARP Conrod Bolts
Pocketed Pistons
Uprated Cams
During rebuild the engine was Bored and Honed for increased compression
Head and block has been skimmed, decked, polished and ported
Omex 200 ECU
Bespoke exhaust manifold
High Crank starter motor
S2000 Radiator (from Westfield)
Carbon Fibre Exhaust silencer (from Westfield)
Lightweight Race Battery (from Westfield)
Dual battery connector for cold start
New cooling hosing
Body
V8 Bonnet
Carbon effect Dash
Carbon effect Boot lid
Carbon fibre effect console
Carbon fibre effect cycle wings
Carbon fibre half doors
Fibreglass Aeroscreen kit
MSA Specification half cage
Waterproof Carpet Interior
Quaife Nylon Gear Knob
Westfield racing seats
Luke 4 point racing harnesses
Suede Steering Wheel
OMP back/head rest
Wheels, Tyres, Brakes, Gearbox, Suspension and Drivetrain
AP Racing 4 pot disks and callipers
Mintex Pads
Type 9 gearbox with Quaife semi helical gear kit
Ford Sierra Limited Slip Differential
Ford RS clutch Kit
Protech Shocks and springs
Wide Track front end
Team Dynamics Pro Race Wheels 1.2 – 13 inch
Nankang AR1 tyres – only 2 track days use (what a tyre!!)
Spares that come with the car
Windscreen, mirrors, side wind deflector, wipers and motor
Stormforce car cover
8 litres 10-60 Racing Oil
Oil cooler
4 part worn Avon CR500 tyres
full set of Mintex brake pads (front and rear)
water pump and belt
HT Leads
Decibel Devil exhaust silencer
5l of 4life engine coolant
softer road springs for Pro shock suspension
Fuel Pump
Petrol Filler cap housing
Radiator Fan
Thermostat
Carpet for interior
Edited by GridMonkeyUK
Deposit taken so marking as sold.
  • 2 weeks later...
  • 2 weeks later...
Now sold.
Bit gutted in a sense but its going to a guy who is going to drive it properly so it's like releasing it back into its natural habitat.
