(SOLD) HiSpec Ultralite 4 Calipers and Mintex M1144 pads
Pair of black anodised HiSpec Ultralite 4 Calipers (M16 mounting spec) and new Mintex 1144 pads. Suitable for solid discs. Calipers have been rebuilt using HiSpec’s seal kit and they’ve been fitted with new Mintex M1144 pads and bleed nipples and anti-rattle clips. No use since. Surplus to requirements. £150+p&p.
I'm interested in these, but I need some help with fitment, due to a complete lack of knowledge!
I'm currently running Sierra uprights, with what I assume are Sierra calipers. These use ventilated discs, which I'm guessing are overkill on a 600kg 170bhp road car
So - I know I'll need new discs, but are these a simple bolt-on job to my existing uprights?
EDIT - also, will my master cylinder be enough for a four-pot setup after only running single-pot calipers?
No. They will not fit.
EDIT: in order to get these to fit, you will need Cortina geometry uprights and hubs (such as Westfield Alloy ones), and to make those fit, you will need to change the front wishbones, and you will need the correct diameter (and fitment) discs.
Been there, done that 😁
Just to confirm, I bought these for my car fitted with Cortina uprights. I had them mocked up so know they fitted with solid 8mm discs, but went no further with them.
Yes they will fit the vast majority of Westy’s but not SDVs 😊
Damn - thanks anyway - at least I've learned a bit more about my car.
Having already got custom extra-wide and caster-adjustable wishbones to go with my Sierra uprights, I really don't fancy the cost of changing everything just to accommodate some lightweight four-pot calipers
