Dave Eastwood (Gadgetman) - Club Chairman Posted December 31, 2003 Posted December 31, 2003 Appologies if this has been asked before The VX red top seems to be covered in numbers, where should I be looking for the engine number? Did a search, found lots of usefull info, but not which one was the right number Ta Quote
Glen_I Posted December 31, 2003 Posted December 31, 2003 Dave, you will find it on the block on the right hand side (looking at engine from front) where the bell housing bolts to block it will start with C20XE OR 20XE then 8 digits, you may have to clean face up with emory cloth to remove any surface rust to read it clearly. Hope that helps.... I am off to get drunk now.......... Glen. Quote
