XTR2Turbo Posted July 28, 2019 Posted July 28, 2019 I need to get a small quantity of parts (only6) laser cut and possibly folded. I see a few companies advertise online. Wondered if anyone has used / could recommend ? David Quote
TableLeg Posted July 29, 2019 Posted July 29, 2019 I haven't used any companies online but what I did was a search for local companies to me and then approached them and asked about doing small jobs. I had many parts Laser cut now and more recently switched to Water jet cutting. Might be worth trying, at least to get a comparison on prices. 1 Quote
XTR2Turbo Posted July 29, 2019 Author Posted July 29, 2019 Material 2.5 or 3 mm galvanised steel sheet. about 500mm long x 200mm wide only looking for 6 or 8 pieces Quote
Mark (smokey mow) Posted July 29, 2019 Posted July 29, 2019 I've been using cutting technology https://www.cut-tec.co.uk/ recently for all of mine, price wise they're the most competitive I've found but their minimum order charge is £150. For folding Essex laser has also been very good. for a small quantity and if tolerance isn't so important you might find water jet cutting will work out cheaper for you. 1 Quote
Howard Posted July 29, 2019 Posted July 29, 2019 I've used LaserMaster in Cornwall a number of times and can highly recommend them. Last time I used them it was cheaper than I could buy the steel for. You can get a quote online depending on the complexity. Definitely worth contacting. 1 Quote
XTR2Turbo Posted July 29, 2019 Author Posted July 29, 2019 thanks all I will check the suggestions David Quote
Plays-Kool Posted July 29, 2019 Posted July 29, 2019 I've not long had a relatively small batch of parts cut and folded by lakeland laser, did a cracking job, decent turn around time and were sensible on price 2 Quote
cast iron Posted July 29, 2019 Posted July 29, 2019 Quote Galvanised may prove a problem as it quite toxic when burned Quote
Mole Posted August 7, 2019 Posted August 7, 2019 We regularly cut galvanised so shouldn't be an issue..with correct extraction.. 1 Quote
NickBW Posted August 7, 2019 Posted August 7, 2019 I have used L.S. Laser Cutting in basildon. They were great and very well prices 1 Quote
