Screw on trumpets for AT power TB,s
Just bought a used set of AT power TB,s for the gen 1 hayabusa but they didn't have the screw on ram pipe/trumpets with them so I'm looking for a set . They did come with the tapered bottom halves of the intake trumpets which are 90mm long does anyone have any shorter ones that would like to swap for mine ?
Thanks very much for the heads up , I've messaged the seller for some dimensions , the size I need look like they screw onto a 52mm thread and have a 48mm bore
The ones on eBay are the wrong size , too small , I've measured mine now and the thread is 54mm screwing on to a 50mm bore , thanks again for the heads up though  , much appreciated
