Aerocatch set, pt number 125 2100, below panel, locking, Black.
As per the title, I’ve got a spare, never used set of Aerocatches, they are the below panel type, in black, with locks.
I bought them for the FW boot lid, and started the process of fitting them, hence they may be a little dusty. However, once I’d cut out the openings, I realised that the lid construction process seems to have changed; mine is two skins of CSM, either side of a foam core, and you can’t safely thin this down to fit through panel types, the way you can with a solid lay up of CSM all the way through. I’ve replaced them with a pair of surface mount types, leaving these redundant.
Perfect for fixing bonnets though, but check your boot lid construction in case yours is the same as mine!
£30 posted to a WSCC member, (retail at circa £50).
Hi Dave, I will have these off you. Let me know your payment details
Thanks Darren, PM’d.
