clear out. Alloy hubs & uprights carbon effect wings etc
As per the title I'm having a bit of a clear out.
  1. I have 2 carbon effect wings with side repeaters and moulded studs for mounting to stays. Brought off here but not used £60
  2. Rear arch stone guards in carbon effect £70 FW bodywork.
  3. Alloy hubs with bearings fitted brought here as second hand but not used. No hub caps £80
  4. Standard cast hubs £20
  5. Hi spec alloy uprights £250
  6. 2x7 inch headlights new with bulbs £20
  7. Mintex MDB1890 M1144 pads £50
All items plus p&p
I'll take the pads please Hammie but need to check part numbers (they're needed for Hi-Spec/Westfield four pots).
Are the rear arch protectors for detachable or fixed rear arches ?
I'm led to believe HI spec as they don't fit the Wilwood calipers
 I'm sorry I don't know for sure. I brought them for mine which is fixed and they don't fit.
😁yup
I thought I'd saved my old box lid but can't find it... I'll take a chance on buying them please Hammie and happy to use PayPal. PM awaited.
Hi, what is the width of the cycle wings please?
Gary
PM sent
Gary
Hi, I will measure tonight and let you know
Gary
Hi Gary
They are 200mm across the top and flare out to 250mm
Jon
Hi John
Thanks, I also hear that the wings are also described by tyre size, what size tyres were you running/intending to run with these wings? The wings I'm trying to replace have been described to me as 195 wings.  I'll double check the measurements and get back to you either way so you know where you stand.
Gary
Hi Jon
Thanks, they appear too wide to be a direct replacement. I'll leave them for know. Thanks again for checking for me.
Gary
Hi
in what way do teh rear arches not fit your car (Do you think they may fit an SE Narrow with fixed arches)
Kartingmad
It's  the cycle wings we were measuring, not the arches.
Gary
