Rimstock Wheel centre cap socket
My 1994 car is fitted with the 14 inch Rimstock Alloys that Westfield  supplied at the time, the wheels have a centre cap that is fixed with a stud with three small round holes in.
To remove this stud you need the socket { like a big radiator bleed socket } with three pins in that locate in the fixing stud and allows you to remove it .
Hope that makes sense !
Has anybody got one or knows where I can get one.
Desperate Dave
Renault used to use those type of bolts. Or you could just knock the old ones off and use button headed allen bolts
Not sure if the Renault ones are the same pattern , will have to try and see if I could find one to try.
Hopefully a member may have the right one.
