Have tried locally and had a look online - looking for one or two of the grommets that go in nose cone for bonnet spigots to fix into.. but cannot get the right size at local suppliers
Any one know a source.. or is it a Wf only item??
many thanks
@Ben (bunje) had some of them for sale.
thanks Gents.. spot on..
I bought these they do the job spot on.
Thanks mark..as the ones damperman had suggested arrived yesterday and they are not correct..they have 11mm internal but the 19mm is the od of the grommet not hole size so they are too small!
So will have a look at those..
I had to trim them up to fit properly, due to a slightly different thickness of material on both sides of the bonnet.
Glued them in with Gorilla glue.
