Tim Reid Posted April 30, 2019 Posted April 30, 2019 Hi All, I have the following bits left over from my rebuild. I will be at Stoneleigh on Sunday should anyone want to save on postage. All prices are plus postage. SOLD - Alloy hose joiners... 41mm and 51mm diameter. 150mm long. New. £4 each. SOLD to sparkyw Original Westfield solid fuel line from 1996 factory built car. Used. £10. 1m of 7mm oil, brake, fuel, hose from car builder solutions. Brand new. £5. SOLD - Zetec "hockey stick" from factory built car. SOLD to Skinner12321. SOLD - 1m of 8mm fuel hose. Band new £5. SOLD to Liz03 SOLD - 1m of both red and black 25mm2 battery cable and four hight current connectors. All brand new £20 (sold at £15) the lot. SOLD to Rusty Nuts 2 1/2" exhaust clamp and mounting plate. Used. £4 1x clear standard indicator lens. New. £2. LED Indicators. With resistors is sharing with non-LED lights so you don't need to change the relay. They are used and have black tape wrapped around them as the rubber split a little. Not highly noticeable when on the car. £5
Skinner12321 Posted April 30, 2019 Posted April 30, 2019 hi mate,would you post the hockey stick coolant pipe? if so ill take it
TAFKARM Posted April 30, 2019 Posted April 30, 2019 Ill take the hockey stick posted please, skinner can have first dibs.
Liz03 Posted April 30, 2019 Posted April 30, 2019 Can we have the fuel hose thanks chris and liz Will be at Stoneleigh
Tim Reid Posted April 30, 2019 Author Posted April 30, 2019 3 minutes ago, Liz03 said: Can we have the fuel hose thanks chris and liz Will be at Stoneleigh Yes, I was hoping someone could reuse it but it's not something that can be posted. Shall we meet at the club marquee at 11? I should be easy to spot with a long pipe!
Liz03 Posted April 30, 2019 Posted April 30, 2019 Sorry it's the rubber hose not the metal pipe although is it a new pipe
Tim Reid Posted April 30, 2019 Author Posted April 30, 2019 2 hours ago, Liz03 said: Sorry it's the rubber hose not the metal pipe although is it a new pipe Sorry, my mistake. Yes the 7mm hose is brand new. I've also got an 8mm one too.
Liz03 Posted April 30, 2019 Posted April 30, 2019 Is the metal pipe new or used can we have the 8mm pipe Chris
Tim Reid Posted April 30, 2019 Author Posted April 30, 2019 7 minutes ago, Liz03 said: Is the metal pipe new or used can we have the 8mm pipe Chris Hi Chris, the metal pipe is used, I only replaced as have different requirements for my new engine. Yes you can have the 8mm hose. I assume instead of the 7mm or would you like both?
Liz03 Posted April 30, 2019 Posted April 30, 2019 8mm pipe would be better if thats ok with you Will give the others a miss but thanks for your time Look forward to seeing you on Sunday Chris and liz 1
Rusty Nuts Posted May 1, 2019 Posted May 1, 2019 Hi Tim, would you be willing to accept £15 for the cables and connectors I can collect at Stoneleigh on Sunday. PS tried to PM you it system returned a message saying that you can't accept messages. Regards Rusty.
Tim Reid Posted May 1, 2019 Author Posted May 1, 2019 8 hours ago, Rusty Nuts said: Hi Tim, would you be willing to accept £15 for the cables and connectors I can collect at Stoneleigh on Sunday. PS tried to PM you it system returned a message saying that you can't accept messages. Regards Rusty. Hi Rusty, Go on then. I'll be at the marquee at 11 meeting lots of people. Thanks, Tim
