Zetec MT75 gearbox thrust bearing with spacer
I might try a write up but not a very skilled mechanic and I certainly won’t be done by the end of the week.  😃
I won’t get the parts until Wednesday or Thursday.
I too have ordered this set up for my mt75 from kit spares although it’s waiting for my turbo engine to be finished ahead of final fitting
  • 1 year later...
Hello All,
How many members tried replacing the pin as advised below? What are the results.
Pat
On 16/04/2019 at 10:24, Wessex said:
Hi WillC,
If you are unable to get this.You can replace the pivot pin on the gearbox with a part from Kit Spares TRA0019, and then fit a standard ford release bearing. I have done this on a few so know it works
Malcolm
Is the kit spares pin for if you are using a cable operated clutch in an MT75 with a clutch fork?
I thought the main issue comes where people are using a Hydraulic slave with a spacer bonded on to it? Either slave starts to leak or the bond fails on the spacer?
Correct
  • 2 weeks later...
The only downside I noticed in not using the spacer,is because of the extra travel the bearing
comes of the nose/guide slightly.
